| I was poking around on the BM site yesterday and watched a video on interior painting. Since I'm in the middle of painting my rooms, I thought maybe there might be some tips or tricks I could pick up.
I should mention that I've had no problems so far. They make a point in the video that you should cut in a small area then immediately follow that with rolling on the wall. For example, if you cut in 3 feet of ceiling, you should then follow with rolling three feet of wall to blend in with that line. This technique minimizes the chance that you'll have a visible cut-in frame around the perimeter of the wall. I have to admit I've never done this. I cut in the ceiling, down the corners, and then around the baseboard. THEN I roll the wall. It just seems so crazy to be jumping up and down from the ladder and rolling in-between. Is this technique correct? I'm not sure I'll change my methods, just wondering how other folks proceed. |
- Posted by lazygardens (My Page) on Mon, Dec 13, 10 at 12:09
| You should either have a wet edge (the BM method) or a completely dry edge (your method) when you paint over the cut-in line. If the edge is dried to the tacky stage the roller will pull the cut-in paint off the wall. Here's my method: 1 - Feather the cut-in area out into the room 6-8 inches, from 100% coverage 3-4 inches out from the wall to barely 10% (just visible) at the end of the feather. The goal is to NOT have a straight line of paint. 2 - let it dry completely 3 - When I roll the wall, I cover the cut-in area, making at one full stroke parallel to the wall or ceiling and as close as I can get with the roller. The broad feathered area minimizes the 'framing" effect you get if you have a 4-inch cut in with a hard edge and then cover it with the roller. I also tend to apply paint thicker than most non-professionals, which also minimizes the framing effect. |
| That videos methods may be ideal IN THEORY...but in actual practice...it would be nutso! Besides...if you're chasing a cut-in line around the wall with a roller, and only doing 3' down....what's happening with the edge of your 3' path?!??!?! >>> All that accomplishes is moving your cut-in down 3'!! (Faron shaking his head here!!) Unless you live behind a roller/brush, here's MY perfect technique: Faron |
- Posted by retiredprof (My Page) on Mon, Dec 13, 10 at 18:44
| Ok, good. I actually use both of your methods. Like LG, I do a broad feathered cut-in all around, then roll the walls in columns top to bottom. I also roll over the cut-ins as close to the edges as possible to minimize any brushstrokes. Here's another thing I found curious. The painter in the video used an extension pole when painting the wall--top to bottom of what looked to be a standard 8-ft wall. Of course, as she was rolling from top to bottom she was backing into the room to maintain steady pressure. Looked like more of a hassle than just rolling the wall up close and personal. |
- Posted by lazygardens (My Page) on Tue, Dec 14, 10 at 8:27
| Whether or not to use a long extension pole is up to you. I use Faron's column method, making sure to use enough paint to get good coverage. The #1 noobie painter flaw is they try to do too much wall per roller-full and end up with skips and thin spots. One roller-full does (for me) about a 2x3 section of wall. I make a W or an X and then roll it sideways into the finished part and then top to bottom, ending each column with the one long top to bottom smoothing stroke. It usually works best if you start on your dominant side (right end of the wall for a righty, left end for a leftie) and work around the room that way. Try not to cross your arm in front of your body. Windows ... I do above the window as if it were a small wall, then do under the window, then resume the columns on the other side of the window. |
- Posted by retiredprof (My Page) on Tue, Dec 14, 10 at 17:43
| Another question, please. Assuming you're doing two coats, do you folks cut in twice as recommended in the video? I normally cut in once (depending on the coverage and base coat), and then roll very close to the cut-in edge. I tend to have a heavy hand with the cutting in, though. |
| Are you sure that this wasn't an old video? Really, the speedy dry times of modern day paints makes keeping the wet edge impossible, even for very fast pro painters. The whole method of cutting and rolling as you go is really old school. A rolling pole is always recommended, but this depends on your coordination level. Some people just can't operate one. You should not need to move your body back and forth when using a pole either...you stay in one spot and adjust the length of the pole to a comfortable position. You can cut in once and roll twice, but this is technically cheating. You are right though, depending on the color, one cut in is sometimes enough, especially if you can roll very tight, it may not be noticeable. |
- Posted by retiredprof (My Page) on Thu, Dec 16, 10 at 11:04
| Thanks, everybody. And, Paint Guy, the video is still up on the BM site which is why I thought it was current. Guess the web designer has been working on the Aura pages! |
- Posted by lazygardens (My Page) on Sat, Dec 18, 10 at 15:39
| Prof - I usually only cut in once, but I apply a really thick coat the first time, and roll extremely close to the edges. |
| How about ceiling technique? 8' columns on a wall are manageable but with wide rooms, how do you manage the ceiling without these fast drying paints being tacky for the next section? I want to paint my ceilings last, lol. Bad idea? |
- Posted by christophern (My Page) on Sun, Jan 20, 13 at 5:33
| Bad idea? yes |
| Why? I did this in the bathroom. The paint is so thick it doesn't seem to splatter. |
| It's easier to cut a straight line with the wall paint to a finished ceiling than it is to make a straight line with ceiling paint over your head when the walls are already complete. That is the main reason I do ceilings first, then walls. I suppose if you are using tape though, the order doesn't matter as much. |
| ok then it's about ceiling lines not splatter or something else? I probably will do the ceiling a little lighter or in some areas will anyway. Bathroom was all the same paint. I'm also using matte. Right, but flat for the ceiling. I used the matte B&S all over in the bathroom. Maybe I could do the ceiling cutting in part first but not the dreaded roller part. |
This post was edited by snookums2 on Mon, Jan 21, 13 at 20:05
| Do the whole ceiling part first! Brush the ceiling-paint onto the side wall about 3" down. Now...ALL of the overhead is done! Next, as PG said, just cut-in your walls. At the top, you can leave a 1/2" or even a full 1" of the C-P on the sidewall showing. Faron |
| okay, okay, but it is intimidating to start there! How about ceiling technique? The 8' columns on a wall are manageable but with wider rooms, how do you manage rolling the ceiling without these fast drying paints being tacky for the next section? |
| Flat or vaulted...and how high? Think of yourself painting inside a shoebox! The underside of the "lid" is your ceiling. Obviously, it's rectangular. >>> All you're doing here is painting a ~2'x6' skinny X! >>> For the 2nd section away from the sidewall, start ~1' AWAY from your wet-edge, roll at the slight angle towards your 1st X....and repeat through this X. >>> Use a good Cover!! Faron |
| Have to read through this again but I would never have thought of that! I can do it! Thanks : ) |
- Posted by AnnieDeighnaugh (My Page) on Tue, Jan 22, 13 at 19:47
| I guess I'm an old fashioned gal then as I cut and roll at the same time....I keep a cutting brush in the roller tray, cut it in and roll, cut it in and roll...no up and down as what I need is all in the single tray.... |
| Not that AD's approach is "wrong"...it's just "inefficient". Constantly switching tools is a lot of wasted motion, & increases odds of a paint accident. Besides...Paints dry pretty fast nowadays! Snookums- Faron |
| Thanks for all the detailed instructions, Faron! I need to approach things in an organized way or I get lost, lol. |
Return to the Paint Forum
