| Hi all, I have a question on painting my master bathroom in my house. First, I am pretty sure the drywall is of a regular type and isn't rated for bathrooms. My house was built several years ago,(2007) and was primed when I closed and moved in. I painted shortly after closing with a paint I wasn't really impressed with the quality of. My question is how can I properly seal this drywall where the paint will last longer, look better? Should I use something like Kilz? Should I use a special primer? Will oil based paint work better than latex? I've never had an issue with a bathroom before, but the paint from only a couple of years ago really is starting to show moisture damage and I'm concerned I may get damage to my drywall if not careful. |
| You just need to use a high quality washable paint, in eggshell or better sheen. You don't really need to use a special primer, just a good one. Kilz is really a stain blocking primer used mainly for blocking out water stains or smoke damage. It's not really the best choice for what you are doing. If you do have water stains from the moisture damage, you can spot prime over those with some Kilz in a spray can and then prime the entire surface of the walls with a good acrylic primer, followed by two coats of a good washable paint. The idea is to get your walls to a point where the moisture will roll off the painted surfaces instead of sinking into it and penetrating. Over time, that penetrating moisture can eventually cause damage. The worst thing to use is a flat paint becuase that is completely porous. |
| Exactly what PG said... Our home is 14y/o now, with 3 full baths. THANK G*D I had them spray a S/G-sheen paint during the build! It's still only a mid-grade builders-paint, but the SHEEN is the saving-grace here!! >>> We've had NO problems with the paint/drywall BECAUSE OF the higher-sheen paint. Faron |
- Posted by wrighthouse (My Page) on Wed, Nov 24, 10 at 13:00
| For the most part, I agree with paint guy and and Faron. But to be safe, I'd prime with Zinsser Bin Shellac based primer, and follow that with at least two coats of a good quality latex semi-gloss. Make sure the coats do not go on too thick. As Faron says, even a very thin coat of latex will take days to cure thoroughly. It is also wise to de-gloss between coats of a high sheen paint to ensure the best adhesion of the second coat, which I do with a sanding block loaded with a really fine sand paper. If I'm doing a really big area, I will get some tinted primer for the first coat after the Bin because there is no need to sand that. |
| The alcohol/shellac-based BIN isn't really geared for moist environments. DO NOT use any "Liquid Deglosser" between coats!!! Faron |
| Great info! I am getting ready to paint my bathroom, and this really has helped me out! |
Return to the Paint Forum
