Wed, Nov 14, 12 at 22:20
| Please help! We are removing our old wood trim and putting up new poplar trim, craftsman style, on all our windows, doors, and baseboards. We are painting it white. Should we prime and paint the boards first on saw horses and then mount them and touch up the nail holes after OR mount the boards first and then prime and paint while they are in place on the wall?? I want it to look as excellent as possible, but with that said, I am a DIYer and will be using a brush. I have BM Impervo latex, and do not have a primer pick out yet. Thanks for your help! |
- Posted by christophern (My Page) on Thu, Nov 15, 12 at 4:45
| Get Fresh Start for primer and do it either way. Me, I would install it first, most would not. |
- Posted by coconutlemongrass (My Page) on Thu, Nov 15, 12 at 23:00
| Do you recommend Fresh Start Latex all purpose primer on the new wood? Or do I need to consider Oil based? I know it is an age old discussion. I am hoping to avoid oil based, but it seems it is maybe the better choice. |
- Posted by christophern (My Page) on Fri, Nov 16, 12 at 4:31
| It might be the better choice, but again, for me,I would use the latex, most would not. |
- Posted by tuesday_2008 (My Page) on Fri, Nov 16, 12 at 15:15
| I installed what seemed like miles of window and door trim, baseboard, and shoe mold a few years ago. I painted before installation. I lightly sanded the bare wood, primed with Kilz primer, lightly sanded again, painted one coat, lightly sanded again, and applied a second coat. Poplar trim is a nappy wood, thus the grain raised after each application, requiring the light sanding between coats. At the time, Kilz was the only primer I was used to, but Christoper recommends the Fresh Start a lot. May have to try that in the future. After installation and caulking the nail holes, mitered joints, etc, I touched up the paint. Painting before installation is much faster, eliminates taping, floor protection, etc. |
- Posted by christophern (My Page) on Sat, Nov 17, 12 at 4:09
| Like I said, most would not.(:-) |
- Posted by coconutlemongrass (My Page) on Sat, Nov 17, 12 at 12:59
| If I install the trim and paint after, would you recommend caulking all the seams on an arts and crafts style window trim? I am going to pick up my Fresh Start primer and we are starting today. It looks like we may install it all first and paint after. It is getting cold here and painting trim in the unheated garage is probably not a good idea anyway. |
- Posted by christophern (My Page) on Sat, Nov 17, 12 at 17:31
| Good idea if it is below 50 where you are and yes I would caulk seams after priming first NOTE do NOT use pure silicon caulk! |
- Posted by coconutlemongrass (My Page) on Sun, Nov 18, 12 at 21:51
| We just finished putting up the trim on our first window. Is any wood filler appropriate for filling the nail holes before we paint? What grit sand paper should I use after the first coat of primer. Thanks for all the help! |
- Posted by christophern (My Page) on Mon, Nov 19, 12 at 4:49
| wood filler, yes 220 grit paper |
Return to the Paint Forum
