| I am going to do some painting in which one room has wallpaper. The owner does NOT want the wallpaper removed, she wants it painted. Apparently there was a wallpaper removal project in another area of the house. It seems the paper was not installed correctly, maybe over bare sheetrock. Anyway, it came off in postage stamp sized pieces and left the walls a mess. She does not want to go through this again. I have only done one other paint-over-paper job, and that was in really good shape and went well.
The wallpaper is in good shape, appears to be well adhered, without any peeling. EXCEPT. The room is three sided, with a large open entry on the fourth side. So, where the room wall meets the hallway wall at an outside corner, the wallpaper just stops. At this corner, the paper is a little worn, and maybe 1/4" or so has pulled up. I will need to stick it back down before I paint. My question is, what is the best method to re-adhere this area, of perhaps a few feet of height by 1/4" wide? I am planning on two coats of primer and two coats of paint. Please advise any other steps I need to take to make this a success. Thanks! |
- Posted by christophern (My Page) on Sat, Nov 26, 11 at 5:17
| joint compound, oil based primer is a MUST |
| The Ben Moore paint site recommends using clear caulk to seal edges. |
Here is a link that might be useful: Ben Moore - painting over wallpaper
| Thanks to both of you for the tips. I'm embarrassed that I didn't think to look on a paint site for info. My husband has suggested using a shellac based primer instead of oil based. It smells a little better, and dries faster. Any comments? |
- Posted by brushworks (My Page) on Sat, Nov 26, 11 at 15:29
| Don't try to stick it down. Remove it. Use a straight edge and level to mark and cut away the loose edge. Fill and feather the edge with drywall compound and sand it smooth. Be sure to caulk the seams at the baseboard and any other wood trim. This will prevent future seam lifting. Caulk after primer. Wash the walls before proceeding. Dirt will keep ANY paint or primer from adhering. If the wallcovering is paper, you can use GARDZ as the primer, followed by two full coats of paint. If you need to block out the wallcovering design, your only choice is an alkyd primer, similar to Coverstain. |
| Brushworks, I don't understand your last statement. All I really remember about the wallpaper is that it is dark with ugly flowers. What should I be looking at? |
- Posted by christophern (My Page) on Sun, Nov 27, 11 at 7:01
| coverstain would be best your'e husband said shellac based would not smell as bad he is very wrong coverstain makes a low odor, which just means it does not small as bad as the regular it still smells, but Bin smells way worse |
- Posted by brushworks (My Page) on Sun, Nov 27, 11 at 10:43
| If you need to block out the wallcovering design, your only choice is an alkyd primer, similar to Coverstain. All I really remember about the wallpaper is that it is dark with ugly flowers. What should I be looking at? Coverstain. |
- Posted by christophern (My Page) on Tue, Nov 29, 11 at 5:05
| I think, maybe, you want, Coverstain |
| Well, after all that, she's decided to hold off for a while. But I'll mark this thread if/when they decide, or until it comes up again. And Coverstain it is. :) |
Return to the Paint Forum
