Regal vs Regal Select
Posted by summer71 (My Page) on
Sun, Nov 13, 11 at 19:23
I am wondering if anyone has any recommendation in terms of using Benjamin Moore Regal vs Regal Select. This is for interior work.
Thank you :)
RE: Regal vs Regal Select
I've used both and I prefer Regal Select. It is a bit thicker and I think it splatters less.
I just finished painting my finished basement. I used Regal Select for the first time. I used the eggshell finish for the first coat and found it shinier than the Regal. I switched to the flat finish for the second coat. The flat is closer to the Regal eggshell.
The Select is thicker but it doesn't have additional drag. Drying time is a little shorter, and a little less smell. Since it is only $3 more per gallon, I will continue using it.
Return to the Paint Forum
