Sun, Nov 20, 11 at 16:47
| I just took down wallpaper, sanded, washed and primed the walls with oil based primer. I used a 1/4" nap Prudy roller and the texture is a lot rougher than I expected. Will the finish coats of paint smooth out the texture or should I sand again? Thanks!!! |
| Keep sanding...OR...have the wall skim-coated to smooth. Re-skimming NOW is a GREAT time to do it since wall is primed! A good skim-job can add value to the home if it's done well. You'll have to re-prime, but now you can use a Latex primer! Faron |
| Thanks faron for taking the time to answer. Guess I'll keep sanding....uggggh! |
Return to the Paint Forum
