Questions about Peel Bond and Mad Dog
Posted by Michele222 (My Page) on
Wed, Nov 9, 11 at 15:07
Our dining room is the only room in the house that has painted trim. We have five bent glass windows so half of the room has an oval or rounded shape.
We painted the trim with a good oil based paint about 20 years ago. Overall it is in pretty good shape. There are just a few spots where the paint has chipped or has a crack or two in it. The original finish was a shellac coated dark mahogany color. Then it was painted with a lead based paint. and then our oil paint.
We could replace the trim where it is the usual flat style but the bent wood trim in the rounded part of the room might be difficult for us to mill and replace.
Do you think that either the Peel Bond or Mad Dog products might help fill in where the paint is chipped or cracked?
I understand that these products are not meant to encapsulate lead. We have no small children and just want to tidy up the trim for repainting.
I'd like to fill the depressions for a smooth finish. I do not want to strip the whole room nor do I want to sand with the lead paint being under there.
I have also heard of Peel Stop but have the impression that it will not fill in the chipped spots.
Thank you so much for your advice.
RE: Questions about Peel Bond and Mad Dog
I have just been reading about lead paint encapsulation. Fred, my favorite painting professional has his lead paint certificate from the state of Massachusetts. He told me about the classes last year. I suppose I should ask him about encapsulation.
We removed all of our interior trim when we moved in. My husband has milled all new old fashioned trim for our house in his workshop. The new trim has been stained.
I wonder if anyone on the restoration forum knows whether mills will make new bent wood trim and how awfully expensive it is.
As someone mentioned here on the paint forum the search engine is not very helpful. When I look up paint info it directs me to gardening information.
Replacing the trim in an old house should be a last resort, IMO, and that's what you will hear on the Old House Forum. I have been scraping and sanding the trim in my 1919 house for a while now and my body lead levels are fine (no children in the house, past child bearing age). So, IMO, renovation is possible.
Personally, I could live with some visible, painted over chips and cracks as part of the charm of an old house.
You might want to look at a product called Trim Magic. It is the trim version of Peel Bond.
Should double check with manuf. but I'm pretty sure Peel Bond and Trim Magic CANNOT be used over oil.
Neither the can nor the technical data sheet mention that, Funcolors. It says only "be sure the surface is clean and dry, free from dust, grease, wax, oil, and other surface contaminants."
I used it over an oil based primer. I didn't see much of a result, but may not have applied it heavily enough.
Thank you so much for telling me about Trim Magic. It may do the trick.
When we bought our house the trim that we removed had been painted over the shellac without being primed or properly prepared. The paint was split with the old shellac finish showing through all over the house. The wood was poplar.
We decided that it just was not worth the effort to strip all that poplar. My husband milled new trim in the original style but in white oak.
I did strip all 54 of the turned balusters and the rest of the staircase. It took a heck of a long time to get it all clean enough to be refinished. There were some broken parts where my husband made repairs with new poplar.
We found a great guy who has done finishing work in some important old New England homes. He did a wonderful job of getting all of the sections to match. He had to do it in a walnut color to achieve a nice allover look. He used a Zar gel stain.
The stairway stands as a sort of antique in the middle of the house. He really made it glow.
Part of my concern about sanding or scraping the lead paint is that we have two small terriers. I would not want to expose them to the dust and chips.
I am very grateful to all of you for your advice.
Michele
I tried Peel Bond on the sides of my home and it did well so I wanted to buy some more. I've found a vendor, but mysteriously many of the places locally that the Peel Bond site said carried it, only had a can. One had discontinued it because, he said. of lack of demand. That makes me uneasy. It seems like a good product but if it is, why isn't it getting scooped up?
Return to the Paint Forum
