Fri, Nov 11, 11 at 14:35
| I've read through old threads and it sounds like you guys often recommend priming with a coat of the room paint instead of primer. Is that because it's better? Or just as good, and so you only have to buy one product?
We've done some drywall patching around our house, in probably 6 different rooms with different wall colors. It seems simplest to go around with a roller and brush and prime all the repaired areas in one fell swoop, then go back room by room with the appropriate color. But is there a reason to instead use the room paint as primer? Just trying to understand the chemistry here. |
- Posted by brushworks (My Page) on Fri, Nov 11, 11 at 16:41
| Paint isn't primer. Primer adheres to the substrate much better than any paint, it seals the surface, hides and blemishes, stains, etc., and prepares the surface for two topcoats of paint. Repainting over clean dull paint is fine, but if you have a patched surface, primer is always the correct first step. |
- Posted by christophern (My Page) on Sat, Nov 12, 11 at 5:05
| What he said. |
Return to the Paint Forum
