| Have been reading recent posts on painting over stained wood and learned a lot but am still a little confused.
I want to paint wood stained kitchen cabinets (with a brush) white. It seems that the alkyds will give a nice hard finish but will also yellow over time. What primer and paint would be durable for a kitchen cabinet but not yellow? |
- Posted by christophern (My Page) on Sun, Nov 20, 11 at 4:57
| Fresh start oil primer and Ben Moore Satin Impervo (waterborne) |
- Posted by fnmroberts (My Page) on Sun, Nov 20, 11 at 9:46
| You're right, oil based will yellow and besides are almost unavailable today. I painted our cabinets about a year ago. Found some useful advise and followed it with good results. Here is sort of my recall: If you are adding/changing hardware, fill holes or drill for new before anything else. Here is a link to our photos.
Here is a link that might be useful: Kitchen, Before and After
- Posted by brushworks (My Page) on Tue, Nov 22, 11 at 7:56
| Some tips to help you achieve maximum beauty. Be sure to caulk any gaps on drawers, doors, stiles, rails, etc., and tool the caulk to a smooth finish. (caulking is always done after primer dries). Allow 4 hours for caulk to skin over. Paint the stiles and rails first. This will give you time to become comfortable with the paint and brush. Since the stiles and rails are less visible parts, it's the ideal place to practice.
| It's of lesser importance overall, but... What type of wood are your Cabs? Again, I only mentioned this because some people are disappointed when their Cabs aren't "smooth" after painting! Faron |
| Thank you all for the helpful information. At the risk of sounding Very stupid I need to know if the Fresh Start Alkyd is the Fresh Start oil base primer you refer to. I'm guessing that if it is, I don't need to worry about yellowing since it is only the base coat? Thanks again for your patience. |
| Yes, for all practical purposes, you can equate "Alkyd" with "Oil-base". Actually your question is a relevant one, because many people get confused on it... Faron |
| Im doing the same to my bath cabinets. I put 1 coat S/W Oil primer/stain killer/sealer. Thats the only thing I done so far. I did sand with my orbit sander and cleaned it before the primer. Is one coat enough primer? Should I put on a clear coat of somekind? The closest Ace is 40 miles, So S/W is my 1st choice unless B/M will be worth the drive. Im planning on rolling the fronts with a 4" flockfoam roller. The paint is semi gloss. |
| Obrion- You did the right prep and used a good primer! Forget the "Clearcoat" temptation/fallacy... Complete "Cure--THRU"....CAN....take a month. As I mentioned previously, you can apply more primer IF....IF...you want to slightly fill in any graining. When you're at your SW store, pick up some of XIM's Latex X-tender for your paint. This is a very good "relaxer" for the paints' binder resin, giving you more working-time before it starts to "set". Leveling is therefore enhanced as well. >>> Use good technique AND equipment too!! Faron |
| So what do I need to let cure for at least a week? The primer? the cabinets before re-installing them? |
Return to the Paint Forum
