| We need to buy doors and trim for an entire 1800 sq. ft. home. When I found out we could buy pre-primed doors, my ears perked up thinking how much time that would save me in painting. My husband paints the walls, and I do the trim. :-)
I want a really professional look, so when I paint I always sand the door first and then lightly sand after each coat. I find that it makes a difference. I wonder if I'll get as good of a result with the pre-primed door. Would you recommend using pre-primed woodwork? Thanks so much! |
- Posted by sombreuil_mongrel (My Page) on Sun, Nov 14, 10 at 10:34
| Hollow-core masonite doors always come already primed. Solid-core or wood doors with a pre-primed option are a good idea if you're painting anyway; the manufacturer can't say that they warped because they were left unfinished for too long. The thing is, they won't be solid wood, they will likely be a lumber core with a masonite (hardboard) "veneer" glued on. That's what the last bunch of them that I installed turned out to be. If you really want an all-wood door, you now must order stain-grade (and they're veneered as well). Casey |
| Personally, I do not like pre-primed woodwork because it is garbage wood, melded together with finger joints and then primed with watered down garbage primer. Over time, the joints move and open up. But, the pre primed wood is cheap which is why everyone likes it and it looks good for a while. When we paint new homes, we actually prime over the pre primed wood with high quality primer...yes, I know it sounds silly to apply primer to primer, but the industry is what it is. I think pre primed doors are okay though. |
| okay.....so what I'm hearing you say is.....not to buy pre-primed woodwork, but the doors may be a possibility. ?? We definitely don't want hollow doors, but we haven't decided on whether to get solid core or wood. We're going to go and look tomorrow. Which would you buy if it were your home and money was no object? (just hypothetically speaking) :-) I've heard real wood has more of a chance of warping. But is that really a problem? We live in Indiana, and we use AC or heat to keep our home at a moderate temperature. sombreuil_mongrel, you're saying that even doors sold as wood doors are NOT solid wood? They're veneer? Can that really be the case? Thanks for your replies!
| I would probably purchase the solid core masonite doors if it were my home and I was painting the doors. You really don't want real wood doors because of the warping and because they have those floating panels. The panels move around and when they move, the paint will crack or if you caulk those gaps to hold the panels in place, the caulk may crack. The panels at some point always become a problem so IMO those doors are really not meant to be painted even though some people do. |
| Paintguys 1st post is GOLDEN. Low quality primers are used. Faron |
| We got our doors today......solid core Masonite doors, 2-panel Roman arch style. I was actually surprised at how solid they were. We were told to be sure to paint every surface on the door, including the top, bottom and hinge area. We got primed, but this was a far cut above primed wood we saw in the big box stores. This lumber mill had quit carrying hollow-core doors because they didn't think they were a very good product, but they said we should get many years out of this solid core door. I really loved these doors, so I hope we've made the right decision. Thank you all for your help! |
Return to the Paint Forum
