| I painted my bathroom 6 months ago with ProMar 200 by Sherwin Williams and the paint is still running down the walls. I'm not kidding there are paint streaks on the walls after the shower has been used.I can wipe the paint off the wall with a damp cloth. I cleaned and primed the bathroom walls before I painted to make sure I got a good finish. I've painted every room in our house and have never had this problem before. Has anyone else had this problem? I'm totally disappointed with Sherwin Williams ProMar 200 and will never buy this product again. |
| It sounds like the paint never dried. It's not the paint....ProMar 200 is a quality paint. If the paint has never dried and then you shower and moisture ends up sitting on paint that isn't dry that is what happens. When you repaint, use the fan in the bathroom, don't shower for a few days...whatever you have to do to let that paint completely dry. Also, showering with the door open for the first month can help as well. Paint takes about that long to fully cure. |
- Posted by brushworks (My Page) on Fri, Oct 26, 07 at 21:06
| It's obviously only happening in the bathroom. Right? Your problem is called, surfactant leaching. |
Here is a link that might be useful: Leaching
| Jazzy, SW makes some very nice paints...BUT... ProMar 200 is in their "low-tier" contractor line. >>> These points are SOME of the reason you're having trouble. The main issue is as Michael outlines. Faron |
| She said she was wiping actual paint off the walls though....that's more than leaching, unless she actually thinks it looks like paint running off the walls and it's not. |
| Hmmmm...some pigment may be coming off with the surfactants present in the "leaching". Jazzy...also... Faron |
| I think it's that Water Whitening business. I've seen it a couple times in person (my own bathroom is what started my quest for info) and several subsequent posts about it on forums. I have noticed that the cheaper paints can let go of color along with moisture and surfacants. The better grades/brands recover from the water whitening quicker and more gracefully. And, they have a better chance of releasing the surfacants to the point of the problem completely going away with time. I'm sure the PQI guy could explain, dunno. It can look like the walls are bleeding and people's first inclination is to wipe them down. I kinda think the best thing to do is leave it alone. Make sure the bathroom is well ventilated, let it dry out naturally each time and just wait it out til one day it just goes away. "rmichael ----------------------------------------------------------------------
---------- "Water-whitening" can sometimes happen with latex-based coatings. Enough moisture makes its way into the coating film to swell the polymer particles, which normally are not 100% fused even though the pant has dried, resulting in micro-gaps which scatter light, thus causing the whiteness. It of course is not noticeable with white paints, but it can be with clear latex films, and with medium and dark colors. Tinted paints are generally made with more surfactants (soaps) than are white paints, which increases the tendency, because the surfactants increase water absorbancy by the dried paint. When the streaks dry out, the light scattering drops off, and may disappear altogether. As the shower is used over time, and condensation extracts the surfactants from the paint, whitening tendency will decrease." Just the nature of the acrylic beast..Makes sense to me.... " |
- Posted by brushworks (My Page) on Sat, Oct 27, 07 at 6:52
| Summary. Use bathroom paint. PermaWhite, not ProMar200. Michael |
- Posted by jazzygardener (My Page) on Sat, Oct 27, 07 at 9:24
| Hi, Thanks for all the follow-ups. The color I used is called "surfer". It's a med teal color. I was having problems getting the paint to dry when I started. I put fans in the bathroom and had the door and window open for ventilation but, nothing seemed to work. I called Sherwin Williams twice and all they told me was that it would take over 48 hours to dry. I've painted this bathroom before but, never had this problem. The paint color really is running down the wall. Every morning there's teal blue droplets of paint in the shower and sink. If I wipe the wall down with a damp cloth the paint color is on the cloth. I did some stenciling around the top of the room and the stenciled on paint has held up fine it's just the Promar 200 that's running. What's a better quality bathroom paint, something other than SW. What can I do? Do I need to re-prime the walls and start over? |
- Posted by brushworks (My Page) on Sat, Oct 27, 07 at 9:43
- Posted by paintshoppes (My Page) on Wed, Jun 10, 09 at 20:39
| Aura Bath&Spa by Benjamin Moore will take care of your problem. |
Return to the Paint Forum
