Tue, Oct 12, 10 at 12:44
| I am getting ready to paint door frames that have old paint drips on them. How do I get rid of these before I start to paint? Will a paint scraper work or do you sand them down somehow? They look like latex paint. Is floetrol a bad thing to add to the paint? I am worried about roller marks showing. I am using a semi-gloss Sherwin Williams Duration paint. |
- Posted by lazygardens (My Page) on Wed, Oct 13, 10 at 19:58
| I use a sharp wood chisel and slide it parallel to the wood to shave off the drips. Then I sand it if it's obvious. I use the chisel because I like it, not because it's "the correct tool". You can also use the popular 5-in-1 painter's tool, or a flexible putty knife to knock the top of the drip down to where sandpaper can do the rest. If you sharpen the blade part of the 5-in-one they can remove a lot of drips in a hurry. Razor blades are harder to control, but they can work well too. |
Return to the Paint Forum
