| I've read many old posts by searching the forum, but would like to confirm that I've got everything correct.
We have removed a wallpaper border in a room. The border was applied over a satin latex paint and came off very easily. We have washed the walls with a TSP solution and then rinsed. There is no damage to the walls, other than a few nail holes. The next few steps I think I need to do are: - scuff sand walls, then remove any sanding dust - apply one coat of Gardz primer; I am using the Gardz because of its ability to seal in any residual glue/paste from the border - spackle any nail holes - paint Am I correct in thinking that I don't need to apply another primer after the Gardz? I was going to apply it over all the walls (not just the border area). Thank you for any help! |
| It sounds good, except for that you should do all your patching before applying the Gardz. Gardz is also a fine primer so priming over the patches will seal them so that your topcoat will not soak in over the patches at a different rate. |
| Thank you! |
Return to the Paint Forum
