Doesn't look right
sand1502
9 years ago
LIFEYou Said It: ‘Just Because I’m Tiny Doesn’t Mean I Don’t Go Big’
Changing things up with space, color and paint dominated the design conversations this week
Full StoryTRADITIONAL HOMESHouzz Tour: New Shingle-Style Home Doesn’t Reveal Its Age
Meticulous attention to period details makes this grand shorefront home look like it’s been perched here for a century
Full StoryDECORATING GUIDESMeet a Houseplant That Doesn't Mind Neglect
Got better things to do than remember to water your houseplants on schedule? Schefflera will forgive and forget
Full StoryPRODUCT PICKSGuest Picks: Decor That Doesn't Scream 'Halloween'
Subtly moody art and accessories can work well around the home for October 31 festivities and long after
Full StoryWhen a Column Doesn't Look Like a Column
See Why Designers May Opt for Tree-like Supports in Wood or Steel
Full StoryDECORATING GUIDESWorking With Pros: When a Design Plan Is Right for You
Don’t want full service but could use some direction on room layout, furnishings and colors? Look to a designer for a plan
Full StoryWORKING WITH PROS5 Steps to Help You Hire the Right Contractor
Don't take chances on this all-important team member. Find the best general contractor for your remodel or new build by heeding this advice
Full StoryHOME TECHBetter, Smarter Smoke Detectors Push All the Right Buttons
No more bashing in that smoke detector with a broomstick at 3 a.m. — if you haven't already yanked it out. Welcome the new, civilized breed
Full StoryKITCHEN APPLIANCESLove to Cook? You Need a Fan. Find the Right Kind for You
Don't send budget dollars up in smoke when you need new kitchen ventilation. Here are 9 top types to consider
Full StoryGARDENING AND LANDSCAPINGPatio Life: Step Right Outside
Here's how to make your move from indoors to patio or deck so smooth, you almost don't see the threshold
Lori A. Sawaya
sand1502Original Author
Annapolis Painters · East Providence Painters · Plymouth Painters · Lathrop Painters · McLean Painters · Pikesville Painters · Vermilion Painters · Cranford Cabinets & Cabinetry · Brandon Flooring Contractors · Cincinnati Flooring Contractors · Fox Chapel Flooring Contractors · Kent Flooring Contractors · Laconia Flooring Contractors · Randolph Flooring Contractors · Valencia Flooring ContractorsLori A. Sawaya
