Tinted Primer vs. untinted
Posted by chefwong (My Page) on
Sun, Sep 19, 10 at 14:00
It's been awhile since I've painted...
The last coat was Muralo Ceramic.
I plan to repaint the kitchen and living/dining rooms.
All different colors.
Should I just go ahead and prime all the walls with untinted primer which is a +++ cause I can just buy a 5 gallon bucket.
Or it's ALL in the prep and it's best to use a tinted primer that is tinted to whatever paint I am using.
RE: Tinted Primer vs. untinted
It depends on the colors you have chosen. If you have picked a color that will not cover the white primer in two coats, then you may have to apply an extra coat.
if the walls have been painted before, you don't need a primer unless you are covering up strongly different shades.
Dark colors over light - a grey primer helps
Light colors over dark - a white primer helps
Other than that, unless you have extensive wall patches to cover, just paint.
Return to the Paint Forum
