| I applied a slow drying oil based primer to two re-glazed window sashes. One sash dried just fine in two days and I went on to topcoat it.
The other sash feels sticky. It's been six days now. I am doing this inside the house, but it has been rainy, humid and cool this week, so no opportunity to get it out in the sunshine. And with the windows open and no air-conditioning on, it's humid in the house. Does humidity affect the dry time of oil-based primer? I've had a fan on it. I stuck it in the bathroom for a day with a space heater at 90 degrees. I'm wondering whether I mis-gauged the curing of the DAP-33 and primed too soon, but the glazing had two weeks to cure. Any suggestions, other than waiting? The humid, cool weather is expected to continue for days. |
- Posted by brushworks (My Page) on Sun, Sep 25, 11 at 10:44
| I would guess it's the glazing putty solvents pushing up through the primer, keeping it tacky. What was the thickness/depth of the glazing putty? Dap-33 can take from 4 to 6 weeks to skin over enough for paint. Did you remove the contents (the putty) and stir it well before application? Was the tacky window your last one? If so, most of the solvents that settled on the bottom of the can is keeping it tacky. I abandoned the oil based putty many years ago and switched to Aqua Glaze. |
Here is a link that might be useful: Aqua Glaze
- Posted by sombreuil_mongrel (My Page) on Sun, Sep 25, 11 at 11:08
| If the oil is still drying in the putty, the primer can't dry. But if the non-drying isn't just at the puttied area, then some other factor is in play. If you used any kind of stripper and failed to completely remove or neutralize it, that will cause the paint to not harden or fail prematurely. And, of course, externals also play a part in getting primer to harden. If all of the primer wasn't drying right, I'd suspect the paint itself. When you get primer tinted, especially with black colorant, it's a very good idea to thin the paint and add japan drier to encourage it to harden. This is for oil primer only. Casey |
| I finished a tub of DAP 33 during the process, possibly on this sash, I don't remember. Reading between the lines of both responses, it looks like I need to remove the painted-over glazing and redo this sash. Ouch, Aqua Glaze is $25 quart delivered; $112 for 6 quarts. And not sold locally. Sigh. |
Return to the Paint Forum
