painting heat ducts
Posted by halley_rose (My Page) on
Sun, Sep 18, 11 at 8:08
Don't know where to post this for sure, so if I posted this in the wrong forum sorry.
I just bought a new house and the basement, isn't finished. We wired it,and sheetrocked it. On the ceiling there is some ugly metal heat ducts. Not sure how warm they get. They run almost the entire length of the ceiling. We want to spray paint them, with Rust-Olem American Accents stonetextured finish. It's $8.00 and we bought 5 cans to start with. It'll probably take that many more. My questions are it says it's for metal, but how will it stand up to any heat? Can we prime it with any cheap primer for metal, before we put on the expensive paint?
Thanks in advance for your help
RE: painting heat ducts
According to the label, that paint can be sprayed on items as long as the item is not subjected to heat over 200 degrees. Heat ducts don't get that hot.
However, it also says not to use it on galvanized metal. I don't know whether the metal in heating ducts is galvanized or not. (I think not, but I don't know.) If it is galvanized metal, you might still be able to use it if you apply a primer first.
Unless your home is quite old, the ducts are aluminum. Yes, they will hold paint.
I recommend cleaning them thoroughly. White vinegar would be my recommendation as it will remove any remaining oil from manufacturing and not leave a soap residue.
Why spray paint? It's expensive and paint overspray will be all around. For the $40 you have invested, you can buy a gallon of quality paint from a local paint store and they can advise you about their best product.
Good luck and enjoy the new home.
Return to the Paint Forum
