Primer question
Posted by jmc01 (My Page) on
Mon, Sep 10, 12 at 5:27
Is there a difference between drywall primer and plaster primer? I've got extra BM plaster primer and I have a new drywall wall that needs priming. Should I use my leftover plaster primer on the drywall?
RE: Primer question
What is the exact product?Probably,yes, it will actually tell you this on the side of the can.
Read the label
RE: Primer question
probably, christophern, it didn't tell me on the side of the can. That's why I came here and asked. Stupid move on my part, eh?
RE: Primer question
No need for the smart remark. If it is a quality primer it will tell you what it is made to prime. If you got it at HD or Lowes, I cannot help you
RE: Primer question
If it's primer for REAL plaster, it's usually tolerant of plasters' higher ph. It should be fine on sheetrock though.
What exact BM primer-series is it?
Faron
RE: Primer question
The label doesn't tell you? Hmmm. Very suspect. There should be no problem using a plaster primer on drywall, it's just the reverse that might not be OK.
I'd still like to see that label though.
Return to the Paint Forum
