| This is posted on the Old House forum too, I didn't know which forum would be best...it is an old house:
So, I have a problem. On my front porch is a railing, and 5 posts holding the roof up. The posts are wood, with the exterior wrapped with some sort of thin aluminium veneer. It is not smooth, but ridged, much like vinyl siding is ridged.
What do I do? How do I paint an aluminum surface that 1. isn't flat 2. already has some sort of epoxy covering/paint on it? I see all kinds of guides on how to paint bare aluminium, but that's it. Would a regular primer work? I'm confused. I can't take the wrapping off the posts because then I'd have to take the railings off. Any advice? |
| Yes, a regular acrylic bonding primer would work just fine. You should clean the aluminum and sand it before priming. Just because the surface has some texture on it shouldn't make it much more difficult to paint. |
Return to the Paint Forum
