| Hi, this is a two part thread..
1. In the past I’ve used the Ace Royal line of paint and have been happy with how it covers and scrubs. I don’t like that every place I touch up, whether it’s an eggshell, satin, or flat Sensations finish, it flashes. Does the more expensive paint like BM or SW do this? A quick glance at some old threads looks like yes. 2. Next, the hardware store stopped carrying Ace and now has a brand called Do It Best. The owner told me it’s even better and is made by Sherwin Williams – which is does say so on the bucket. I bought a 5 gallon bucket for a large portion of our basement in eggshell. Cleaned bare drywall, used 1 coat of Glidden drywall primer because my brother in law gave us an almost new bucket. The first coat of paint didn’t look great but I wasn't worried. I finally got around to the 2nd coat (a good three weeks later) and it looks like it could use a 3rd coat. It’s only been a few hours since I painted but I’d imagine it’s not going to get any better. The color is BM Crown Point Sand. Doesn’t look "terrible" but if you walk around and look close you can actually see flashing here and there where the screws in the drywall were mudded. I’ll also mention there is no natural light in our basement. Is it safe to assume the paint is junk? Lousey primer? Both? I made sure to remix well before using and didn’t go skimpy on applying the paint. I really like the people at the hardware store. They always perfectly match my colors but I don’t think I’ll be buying this new paint anymore. And if spending the money on BM, SW, etc. will fix the flashing it’ll be money worth spent. There’s really no point in keeping touch up paint if it draws even more attention to the spot you’re trying to fix, you know? Thanks in advance! |
| I don't use much SW interior paint or Ace brand, so I can't comment on that. But BM does have minimal issues with flashing. There are other factors of course, and the drywall patches could be flashing because they were not sanded well too. Eggshells and washable paints will always be harder to touch up than flat and darker colors will always be harder to touch up than lighter colors. Also, the way you touch up can make a difference. You should use the same nap size roller that was used when the painting was originally done and you should never use a brush in the center of a wall to do the touching up. |
Return to the Paint Forum
