Best way to paint deep trim
Posted by alan_s_thefirst (My Page) on
Thu, Aug 9, 12 at 13:15
I am using a 1x4 (3/4x31/2) trim - it's quite deep. I am pre-painting it with my airless sprayer using a melamine type paint - "monamel" because it was the toughest, most oil-based type I could find....
I'm getting pretty good results but not as smooth as possible, because I have to do a pass at an angle to get the edges, if you get what I mean so I'm tending to go at 45 degrees to the main surface, in order to cover the edges.
If I were to do a pass directly edge-on, I think it'd be worse.
The results really aren't bad, but I wonder if there's a better way. I recently bought a whip extension (a short, more flexible hose that you use between the hose and the gun) plus a swivel, so that's made it much easier to keep the gun at a good perpendicular angle - you know what it's like with the very stiff hose.
RE: Best way to paint deep trim
Try a roller or brush to get the edges, then spray for the crevices in the face of thew trim.
Are you spraying on horses or keeping the trim up somehow? I never have a problem hitting the edges, so this question is confusing to me.
Return to the Paint Forum
