Do I need to spot prime over this?
Posted by buddysmom (My Page) on
Sat, Aug 4, 12 at 10:29
My daughter's room is light yellow, latex paint. She had decorated using friend's handprints of darker/different colors using acrylic water based paint from Joann's (the little 2 ounce bottles).
I want to repaint a medium beige and will prime and then paint. Should I spot prime over the handprints first in addition to the regular priming or will that make those areas darker and show up more?
RE: Do I need to spot prime over this?
My thought would be to use Kilz to seal the hand prints and then prime as usual.
More of an issue is the "raised-profile" the hand-prints will show!!
Ideally...you'll "feather-sand" the edges of each print.
Tedious....YES.
Important?? Also...YES.
I'd use a ~100-grit sanding sponge, then remove ALL traces of dust, then prime everything evenly.
Lastly...your 2 coats of new paint!
Id use a better stain-blocker than Kilz!
Grab Zinssers' 123, or C2-One (much harder to find!), or...Gliddens' Gripper primer @ HD.
Faron
absolutly!
Return to the Paint Forum
