Paint blotch or bleeding through??
Posted by janicedallas (My Page) on
Thu, Aug 9, 12 at 9:48
My tenants painted upon move in approximately 1 year ago. They claim some blotches started appearing about 6 months ago and that they didn't see them before.
I looked at the walls and there is a rather large blotch (about 2' x 3') above the left side of the bed in the MB and also spots (they look like large grease spots) in a 5' x 3' area in the LR. I'm trying to figure out what caused this and also how to cover the problem without it reappearing.
The tenants used flat__________. There is a possibility the previous workers used a semi gloss. HELP
RE: Paint blotch or bleeding through??
BIN
Here is a link that might be useful: primer
They could be from darn near anything....
Food spills, paintball battles, water leaks...??!?!!?
If you're brave, cut a sample piece from the wall. You'll then know if it's from a water leak!
If not soft, wash wall with powdered Dirtex, let dry, and use Chrisn's primer advice.
Faron
To prevent bleeding through, brush on shellac, let dry overnight, then paint. A drywaller taught us that trick many years ago. Really works well when your child has used a felt pen to draw on a newly painted wall.
I also use shellac when painting over bare wood. I skip the primer (cause it doesn't work), paint the first coat, then wait to see if there is any bleed-through and wherever there is, I paint with shellac.
There may be water damage. If gyproc/wallboard has been used, press on it and look for wrinkling to help determine if there is water-damage.
The greasy look above the bed could be caused when there is no head-board. One's hair has grease.
Are they kids in the house?
A personal lubricant? Oh my.
LOL
In a more serious tone, check out GARDZ for primer sealer use.
Hey root, BIN is shellac
Gardz ia a great product for what it is intended for. I would not trust it to block stains
A colored Shellac "could" be used, but Zinsser's "BIN" primer, as Chrisn said, IS Shellac in an Alcohol carrier.
I've used them both, but if I had to choose for you, I'd pick BIN.
In this case...I wouldn't rule out 2 coats of BIN!
Faron
Is it a stain? Is it bleeding?
Have you tried washing it?
Don't discount GARDZ. :)
Again, Gardz is a great product but nowhere does it say it will seal in, out, stains
Recommended Uses � Apply to interior walls, ceilings and
related surfaces. GARDZ is recommended for sealing probleml
porous surfaces such as bare and damaged drywall, plaster,
cement and cementitious coatings, spackling paste and joint
compound, calcimine, stucco, acoustic and texture finishes,
uncoated wallpaper, etc. GARDZ will also adhere to and seal in
old wallpaper paste and adhesive residue.
There is a water leak and those are stains. BIN or Kilz, they both work. I like to use the aerosol spray cans for killing water stains because then I don't have to clean any tools and will choose the Kilz every time because the spray cans of BIN are just too runny and drippy. Be sure to address the leak from the roof or whatever it is above that room first. From my experience, Gardz is more of a sealer, not a stain killer.
Correct, as I tried to point out.
Dear Paintguy,
I see no sign of a water leak. One of the walls is only blotched about 1/3 of the way from the bottom and is an interior wall. The other is an outside wall but the blotch or bleed is limited to a small area above the headboard. Do you still think it could be a water leak?
Maybe there's a dead animal in your wall.
Return to the Paint Forum
