Prep for painting eggshell over semi-gloss?
Posted by BamaGirlG (My Page) on
Sat, Jul 23, 11 at 18:07
Hi! I need some advice. We're repainting our house-- which has white semi-gloss in every room. My question is-- is it necessary to do anything special to the semi-gloss in order to paint eggshell over it? We're not changing color--- the new paint is white as well, so it should cover fairly easily, I think . I really don't want to have to sand all the walls -- so much dust... The existing paint has been there for over 10 years.
I want to go with eggshell because I think it would show less imperfections and might be more preferable to potential buyers... Would it require less prep work to recoat with a new coat of semi-gloss?
Any help or advice would be greatly appreciated! Thanks in advance! :-)
RE: Prep for painting eggshell over semi-gloss?
I would pole sand. It doesn't create much dust at all. You could also wash the walls with Dirtex.
pole sanding, with 120 grit sandpaper is really the best way' should only take 5 to 10 min per 12 x 12 room you can buy large sanding heads say about a foot around to make it go faster
Also consider matte instead of eggshell, less shine and still durable
Return to the Paint Forum
