Scuff sanding
Posted by davisgard (My Page) on
Tue, Jul 12, 11 at 14:06
Do you scuff sand everything except a flat paint? Including trim, walls, and ceiling? My walls have a knock down texture, but I'm assuming the scuff sanding is gentle enough not to affect the texturing.
I don't remember ever seeing a professional painter scuff sand, but I'm assuming it's a good idea for sheen paints, including between coats.
RE: Scuff sanding
It SHOULD be mandatory for painting over a Semi-gloss wall!!
Sanding a Satin wall is optional.
Washing a wall is more important IMO!!
* If it's a more moderate knock-down, sanding can smooth-off any hideous sharp edges.
* Also, even if you have orange-peel, sanding can knock-off any bigger clumps, etc.
* Sanding BETWEEN coats?!?! Rarely, unless your wall is smooth; OR....you're doing "eye-critical" work like trims, cabinets, doors, etc.
Faron
Return to the Paint Forum
