| Hi all. I painted my whole 1940's house about a year ago. The previous owner was a heavy smoker, so I cleaned the walls, then used BIN primer.
In the dining room, the paint begins to peel and crack in about 3 months time. Each time it has showed cracking and peeling, I scrape the peeling paint patches back down to the old green paint. Then I prime, and repaint. I have tried, BIN, I have tried Gartz, and I have tried oil primer, and then repainted (with kelly Moore's highest quality flat latex paint). Each time I think it is remedied, and lo and behold, a few months later, the paint starts cracking again. What to do? Thankyou! |
- Posted by lazygardens (My Page) on Sun, Jul 17, 11 at 14:33
| YOU need to get past the old green paint to the bare plaster. What are you scrubbing the walls with? |
- Posted by christophern (My Page) on Mon, Jul 18, 11 at 6:18
| You never cleaned the walls properly for the Bin to stick. The Bin will cover SPOME nicotine, but not a heavy buildup. |
| I scrubbed the walls with oxy clean. The previos owner- heavy smoker-- had white walls which the paint was a few years old and adhering fine when I moved in. That is the surface I cleaned and painted with BIN. When the peeling started, I scraped the peeling paint off and that is when the old green paint was revealed. Has anyone tried PEEL STOP CLEAR BINDING PRIMER by Zissner? thanks! |
Return to the Paint Forum
