Best primer for new plaster?
Posted by browniepie (My Page) on
Fri, Jun 3, 11 at 13:43
Hello,
Hoping you can help me. I tried to search this forum but could not find a definitive answer.
We have had some substantial plaster repairs completed in our home, and I want to make sure I use the correct primer on our fresh, new plaster walls. Our plasterer recommended and alkyd-resistant primer.
Would Zinsser Odorless Oil Primer meet these requirements? How about Zinsser BIN?
Thanks so much for your assistance!!!
RE: Best primer for new plaster?
REAL plaster or joint compound??
real plaster
Depending on the ph-level/mix of that plaster, usually waiting a month or more is wise.
It takes a while b4 it's ready to prime.
Depending on final topcoat color...
Zinnser's Gardz primer would be good, along with their 123.
Faron
Not oil.
Veneer systems (Blueboard + 1 or 2 coats of veneer) claim to be paintable in less than a week.
Three-coat gypsum plaster over "lath" needs four weeks.
Real lime/horsehair plaster needs 90 days to cure enough before you should dream of painting it.
Beyond those calendars, feel it; if it is at all cool and clammy, it isn't ready for paint; that goes for drywall mud, too.
Casey
Hello, just closing the loop here for the sake of people searching for a clear answer in the future.
According to another paint forum, Sherwin Williams Loxon is the best primer to use for "new" real plaster.
better make sure to remove and wipe off any dust after sanding, or nothing will stick learned that one the hard way
OR, in the case of real plaster if it is still hot to the touch
Return to the Paint Forum
