Brick Stain
Posted by trigrl09 (My Page) on
Thu, Jun 28, 12 at 11:07
We have pink brick! HELP!
Does anyone have experience with staining brick. I have read a lot about painting brick but was wondering if staining would be less work & maintenance.
What brand of stain did you use.
Thanks
RE: Brick Stain
Hopefully Funcolors will see this! She responded on jc_wilson's post about changing his brick. I saw where you gave a "shout-out" on that post.
RE: Brick Stain
I also would like to stain my brickL. I could only find one company that sales the stain.
http://www.dyebrick.com
If anyone knows of another company please post.
RE: Brick Stain
I taked to Sher. Williams rep who suggested HC concrete stain.
Here is a link that might be useful: Stained brick
RE: Brick Stain
The trick is to talk with the product supplier directly. Get samples. Ideally, you have a few extra bricks to experiment with.
Two choices - stain each brick one at a time or reconcile with the fact that you also stain the mortar if you apply broad strokes to entire surface.
Here's what I know, however, no matter how it comes out, people feel it's better than what they started with.
Did I mention to get samples? Stain whether for brick or wood is incredibly challenging from a color p.o.v. I really have no short-cuts, the only way is to sample, test, sample, test, rinse, repeat.
If you have to buy a couple gallons just to test color (and some brands make you do that) then that's just what you have to do.
Staining brick is not like painting a house - get your arms around the parameters with which you must work and align your expectations accordingly.
Did I mention talk to the specific product pro's and get samples ;)
RE: Brick Stain
Did you use muric acid first or just a pressure washer to clean you brick?
RE: Brick Stain
Just power wash but prep depends on which product and its recommend steps.
Return to the Paint Forum
