| How to finish pressure treated lumber gets asked here a lot and I've read through all the threads and could still use some help.
I have a garden shed in SE Wisconsin. The floor is pressure treated plywood and there is a ramp that is pressure treated 2x4s. It's newly built. I've read that new PT is probably 40-50% moisture and not suitable for finishing right away. The builder got the PT from a big box retailer and with my moisture meter, I'm measuring about 20% - I'm guessing it "weathered" at the retailer then? I'm using a Cabot Problem Solver Oil Stain primer which says it is suggested for pressure treated lumber and its main stipulation is moisture should be 15% or under. Appearance wise it still looks rather green, but the moisture meter says not so wet. So really three questions - 1) If it's below moisture levels, am I ok to go ahead and coat or should I still let it weather? 2) Since it was built already, I can only coat top and sides of the floor and ramp - not bottom. Still good idea to finish? I know ideally all sides, but can't do it this time. 3) I was planning to use Cabot solid arylic stain as top coat on the floor with the intent there being to tide me over until I can afford to do some FastDeck flooring. I was going to mix in some sand for the ramp. Good/bad ideas? |
- Posted by Jumpilotmdm (My Page) on Wed, Jun 27, 12 at 13:01
| 1] Go ahead and paint. Your choice of primer was a good one. 2] Don't worry about that. Some will tell you NOT to back coat, even if you could. 3] make sure it's their solid decking and not just solid acrylic, which would be too soft. |
- Posted by snuggles2010 (My Page) on Wed, Jun 27, 12 at 21:15
| Thanks, appreciate the input. Yep, the floor will be the decking stain. |
Return to the Paint Forum
