Staining fence without power washing?
Posted by abufish (My Page) on
Thu, Jun 9, 11 at 0:43
(Also posted on Deck & patio forum)
Just move in to a home with really old fence (15 years). It looks black-grayish.
I did some research online says the best way is to power wash it, then apply some stain. But some friends told me I can apply semi-transparent stain directly to aged fence. Will that stain stay well? Any suggestions? Can I skip power wash? Thanks!
RE: Staining fence without power washing?
Friends that give advice like THAT aren't really friends (LOL!)!!
NO....
You CANNOT skip cleaning/washing that fence.
Unless you like totally wasting your $$$...
* Use a good deck/fence cleaner, let it dwell/react for ~ 15 min.
* Then, use the P/W to hose it off.
* Now you'll have a CLEAN fence, with some original color back.
* Stain will look MUCH better!
* Sikkens SRD, & Penofin Red or Blue-label are very good S/T stains.
Faron
Thank you Faron for your reply!
I don't have a power washer, will high pressure garden nozzle (like a jet nozzle) work after I use some deck cleaner?
1st choice:
Rent a Pressure-washer.
2nd choice:
Rent a Pressure-washer...
. 8th choice:
Use your hose-nozzle.
I'm serious. The P/W will be a much better use of your time, and do a MUCH better job cleaning!!
Just use the 90deg fan tip, & keep it moving.
No closer than 1 FOOT to the wood.
Faron
Faron, thanks, you are right...
I tried today using garden hose with jet nozzle. Not good at all. I tried chemical->brush->rinse, chemical->rinse, and brush->rinse... The only good result sample is the first option, chemical + brushing + rinsing. It is going to be too much work if I have to brush clean the 100 feet of my fences! So pressure washer sounds like the only way to do!
Return to the Paint Forum
