| I really have a problem. I have a deck that was made with treated lumber. Not knowing any better quite a few years ago I got tired of the dark stain so I painted it white. Well, the paint has worn off and I really can't afford to replace the deck so I'm wondering if anyone can suggest a paint that will adhere to this lumber better than the last one I used. It certainly would help me out if anyone had an answer plus the deck needs help as soon as possible. Thanks in advance for any help you could give me. I sure would appreciate it. |
- Posted by colour.me.christine (My Page) on Sat, Apr 16, 11 at 13:25
| Hello brownthumbia, My name is Christine, and I work in the paint department at The Home Depot. I would suggest priming the surface first. Do you know if the stain that is on there is oil or latex based? If it is oil, you will have to use oil based primer, if it is latex, you can use either oil or latex. After the primer is dry, use a paint that is specifically formulated for porches. Typically people apply 2 coats. Check on the back of the can to see how long it takes the paint to cure before you walk on it. Depending on the paint, it may take up to 3 days. I hope this helped you out, Happy painting!
- Posted by brownthumbia (My Page) on Sun, Apr 17, 11 at 19:38
| Thanks so much Christine. I'm sure the dark stain was oil based, but the paint I used over that was latex. that may be where the problem came in. don't think you can paint latex over oil. Oh, how stupid of me. I didn't realize what I did until I just now typed it. But, I will take your suggestion and just repaint it and hope for the best. Thanks again for your help. BT |
| Oh G*D....here we go again... DO NOT PRIME A DECK if using a "Porch & Floor" PAINT!!!! THERE ARE NO P&F PRIMERS! >>> How old is the deck? The ONLY floor primer I'd use is Cabot. It's one of very few out there. Check the link... Faron |
Here is a link that might be useful: Cabot's Deck & Siding primer...
- Posted by christophern (My Page) on Wed, Apr 20, 11 at 4:51
| Well, she did say "happy painting" . |
Return to the Paint Forum
