Primer Q for F&B
Posted by rgustafs (My Page) on
Sun, Apr 17, 11 at 17:39
I am working with a REALLY small, unvented full bathroom with plaster walls. I have sanded and patched and sanded and patched and sanded some more. I am now satisfied that my walls are ready to be painted and am leaning toward F&B -- likely Borrowed Light, but I will get my sample pots tomorrow.
Knowing that my bathroom is unvented, can/should I prime with Kilz if I am going with F&B Modern Emulsion? And do I go with water-based or oil-based?
Many thanks!
rgustafs
RE: Primer Q for F&B
Why is the bath still unvented?
It is VERY important...unless it's not used much?!
If it's daily use, get a fan in there...vented to the outside, as is code.
You SHOULD wash the walls down first, preferably with POWDERED Dirtex.
Use a good primer like Zinsser's 123 Latex, or C2-One.
If it won't be vented...primer-type will make no difference. You're just asking for problems then.
Faron
Thanks, Faron. It is not a daily use bathroom, but I still wish it were vented. The condo was built in the 40s so there are many things about it that are not up to code. One day when I am able to remodel, that will all change.
I have not had issues with the walls in the bathroom in the past 4 years, with the exception of last month when a burst pipe in the upstairs condo unit and subequent half-a$$ed patching by the condo management led me to decide to it was time to re-patch and paint. :)
So...Wash em down with Dirtex then Zinsser's or C2-One. Sounds good.
Thank you!
Return to the Paint Forum
