| I have a wrought iron bench that hasn't been painted in about 10 years and needs a fresh coat of paint. I didn't do the original painting, so need advice on the best procedure.
The paint has faded but is not peeling. It's presently a deep blue but I want to change that to black. Should I prime it? I don't have a good place to spray it, so need to use a brush. It has a lot of open work and I'm worried about paint dripping through and the droplets drying. Do I turn it upside down and paint the bottom first? Paint in sections? Thanks for your advice. |
| Sorry...but it needs to be sprayed! Make a little "Paint-booth" by using hanging light plastic sheets. Use a breathing-mask too!! Hose-off dirt, etc. with a good blast of water, after a good cleaning with some soapy solution. Buy some good spray-paint....maybe 3 to 4 cans. NOW you'll get great results/durability! Faron |
| Sounds easy once it's all set up, but setting up will be tricky. Don't have rafters in the garage - the ceiling is finished. Hmmm. Maybe I can rig some ladders up with two by fours in the high rungs and hang it from those. Have to figure out how to make the plastic tent. Thanks for the advice! |
Return to the Paint Forum
