| I had damaged drywall, so I piled off the damaged face paper, sanded it and applied Gardz to damaged areas only.
Then I put the Sheetrock all purpose compound to fix damaged areas. I sanded it again, and put the 3rd coat of the all purpose compound. Now, I want to know if my next steps are correct: 1. Apply Gardz again over all purpose compound and to remaining wall surface. So basically Gardz everything. Should I Gardz the ceiling also? 2. Paint Do i need any primer or will Gardz server as primer I will paint the walls according to: http://www.benjaminmoore.com/en-us/for-your-home/fresco and it is in the bathroom thx |
| Welcome Bwspot! 1) Yes, Gardz can be the "everything"/all-surface primer, just b4 finish paint! 2) Gardz serves as the primer b4 your paint. That's a neat Fresco look! Gardz will serve fine in your bath. NOTE: Faron |
| Hello, i personally like flat paints. I was thinking about using: but the page that has instructions for that fresco paint has: so it is eggshell finish there recommended So you think those colors are ok with gardz as primer? |
Return to the Paint Forum
