| My sister and BIL just bought an old house. They don't have many cabinets and are very unattractive in their current state. They've decided to paint them a creamy white with glaze.
She was set to use BM Satin Impervo (from my recommendation - I've never actually used it) but the store that carries BM paint, doesn't have that kind. We were then going to use Regal but then after a quick search I found an old thread ... Posted by paintguy (My Page) on Tue, Feb 3, 09 at 19:07
That's making me want to run far away. Thought about using SW Pro Classic but heard scary stuff about that being tough to paint too which is why I thought I was going to be safe with the Impervo. The learning curve of Aura also makes me want to run. Thougths for a DIYer? My next question is the glaze, she's set on using water based paint. How long after the 2nd coat do you need to wait to apply a glaze? After the glaze, I'm assuming we'd want to use a (water based) poly but how soon can that be applied? Do we need to wait only a few days? Or a full month until after the paint cures? I do know we need to do proper cleaning, sanding, priming etc. Thanks in advance! |
- Posted by sheesharee (My Page) on Wed, Mar 30, 11 at 9:11
| I was planning on using Cabinet Coat on someone else's cabinets because I know they want plain old white and I've read good things about it. My sister decided on SW Antique White for color and I didn't think CC could be tinted. It looks like they have a variety of creamy colors and I'm sure one is similar to what she wants. I'm going to look into that more today, thanks! |
- Posted by forboystoo (My Page) on Wed, Mar 30, 11 at 11:13
| Never used it. Don't know anything about it. Probably too new for good reviews. But you can check out the video on how it was applied. |
Here is a link that might be useful: http://cabinets.rustoleumtransformations.com/colors.php
- Posted by sheesharee (My Page) on Wed, Mar 30, 11 at 13:12
| Thanks for the link Forboystoo. I'll keep a watch out and maybe try it later if it gets good reviews but I don't think she'll want me to chance it with the cabinets. Graywings - I called my hardware store and the girl at the register insisted on trying to answer my question. *sigh* I ended up calling Cabinet Coat and they can tint it so that's what we're going to go with I believe. I need to check about finish though. I thought it came in semi gloss and the girl at the hardware store told me just satin. Is that's going to be shiny enough to work glaze? Anyone have any thoughts about the glaze/polys? Thanks! |
| Faron has posted quite a bit on here about Ace Cabinet & Trim paint, which only comes in semi-gloss. I don't know about glaze, but I thought I'd throw it out there if SG is what your sister is after. |
- Posted by forboystoo (My Page) on Thu, Mar 31, 11 at 2:28
| Choochnbob used Cabinet Coat matched to a BM color. Also keep in mind one paint brands satin is another paint brands semi. But do search Farons review on Ace Cabinet,Door and Trim. |
Here is a link that might be useful: http://ths.gardenweb.com/forums/load/kitchbath/msg0412210021044.html
| Benjamin Moore now owns Insl-X, the makers of Cabinet Coat, so you should be able to buy it at a Ben Moore dealer. |
| Yeah....if ya can't beat-'em...BUY-'EM!! Make sure the C-Coat TINT-BASE it used!!! As long as you're in the Satin sheen area, glazing is fine. We purposely don't stock any cab-dedicated glazes, other than normal paint-glazes, which can be used too. Rarely get asked for it...it seems to have come-&-gone to a degree! Faron |
Here is a link that might be useful: Cab-Coat info...
- Posted by cfmuehling (My Page) on Fri, Apr 1, 11 at 10:17
| I just ended up in a BM store by mistake and it's the best thing that ever happened. :) They carried the much vaunted primer STIX, that is a bonding primer and usable on ... plastic. I'm using it on melamine. Those 1980s white cabinets that look so clean, yet now look so dated? And.... The point about the tintable base is not debatable. They must have that in stock or you can't successfully tint the white. It's something to do with the hardening factor, it was explained to me. On their recommendation, and the fact that I'm not so thrilled with how the dark base cabinet color I'm suing is going on, I'm giving them a coat of the same oil-based primer I'm using on all the wooden uppers, then a final coat of the same dark paint. I love the color. I was shocked at how satin smooth the primer was on the upper wood cabinets. I (almost) can't wait to paint all of them. Be careful with glazing. People tend to go too heavy and it not only looks dirty all the time, it looks like "oh, someone's first glazing project." Remember that like vermouth, cyanne pepper, and applying perfume, you can always add more, but you can't remove what you've already done. Start light and think coats. An already wet cheesecloth has always worked well. But that's another thread. Good luck. |
- Posted by forboystoo (My Page) on Fri, Apr 1, 11 at 23:17
| Yes cfmuehling, But in the case of too much vermouth, no need to take away what you already done , just add more VODKA....:) |
| I've got Insl-X STIX primer in too...at our ACE. (It's in the ACE catalogue-any ACE can get it...O/M=4 however) Not the cheapest...$40/gal, but d*mn good stuff! Yes- DON'T have anyone try to tint C-Coat in the White-Base. Faron |
- Posted by tuesday_2008 (My Page) on Sun, Apr 3, 11 at 12:36
| Shee, I used SW ProClassic on a BR vanity - it turned out beautiful. DD painted her cabinets with it also and she had never painted wood in her life. They turned out perfect. I really did not find it difficult to work with. You just have to paint fairly fast, don't go back over what you have already painted because it does get sticky fast. But it is workable enought that you have time to do the job right. I did one coat of primer and two coats of paint. I will use it again on my kitchen cabinets - when I have the time. Tuesday |
Return to the Paint Forum
