Mon, Mar 4, 13 at 21:42
| Would you help me narrow down some cheery greens that will look good with my Hampshire Gray and Berry Red rooms. Since I could never come up with a yellow that worked all times of the day and with my orangey pine floors, I've decided to go with a green. But it needs to be a cheery green. Would love if you could make suggestions from BM's classic colors or affinity line. I have both of these at home. Thank you. |
| Sorry took so long - I'm swamped right now. Yay me! :) I have four green ideas. One is from the Preview deck, however. Dil Pickle 2147-40 (Preview) That is a RANGE of green personalities! All harmonize in their own special way with HC-101. Which one strikes you as cheery might have to be determined with samples in the space. Hope that helps. |
| It does help indeed! Thanks for the green ideas. I had to finally give up on the yellow trail. Overall, I think green is going to work much better, and it's kind of ironic, because you first recommended Edgewood Green when I was thinking yellow for that space. That is still one that I am considering! You have been so kind even after all this and I appreciate it so much. |
Return to the Paint Forum
