Sat, Mar 13, 10 at 16:15
| My husband and I purchased a dresser set last year from an estate sale. It's a painted wood set but we've decided not to strip it (basically because I tried doing it and it was a pain of monumental proportions). Because we are unsure if the paint is lead or not we don't want to bother stripping it. Does anyone know of a primer that is good to use if the piece is not sanded? |
| I believe that Cabinet Coat claims you do not need to sand. There are also liquid sandpapers and deglossers you could use. If it were me, I would just take the thing outside, throw on a respirator and sand it. |
| I use Zinnser bullseye 123, it is more expensive then the normal zinnser primer, but it does state that no sanding is required. It has saved me a ton of time skipping this step whenever it was appropriate. Most of the furniture I have painted (also old pieces) it has worked great on so far. |
Return to the Paint Forum
