| We need to paint the drywall walls inside the garage, as well as the garage side of the door leading into the house and the door to the backyard. Should we use exterior paint, since it will be exposed to temperature fluctuations? Or interior paint, since it will be protected from sun, rain, etc.? |
| Either one is fine! I'd give a slight nod to Exterior paints, since their resins are a LITTLE more flexible than Interior paints. MORE importantly tho... Faron |
- Posted by christophern (My Page) on Thu, Mar 22, 12 at 5:20
| .MUCH easier cleaning there if a higher sheen is used! Right, like he is going to be out in the garage cleaning the walls. I just bet. Not sayin you are not correct, just that it will NEVER happen.People don't clean the walls in there own homes. |
| Thank you! If I use exterior paint, is there primer designed for exterior use, or can I use the same primer I use inside? (I've only ever painted inside the house, so I'm totally clueless in this area.) |
- Posted by Jumpilotmdm (My Page) on Sat, Mar 24, 12 at 11:45
| Exterior paint over any primer. Make sure the walls are clean. Watch out for mildew depending on your climate. |
Return to the Paint Forum
