What Primer after Skim Coats?
Posted by obrionusa (My Page) on
Mon, Feb 4, 13 at 16:16
First I got the wallpaper removed, scrubbed and rinsed everything off. Then applied the Gardz and let that dry. I'm now skim coating any defects in the drywall. What primer would you use before the topcoat? I have some PVA primer in the garage. Would that be ok to use?
RE: What Primer after Skim Coats?
Just use the Gardz, it is a primer. If you NEED a pigmented primer go with Bullseye 123
Return to the Paint Forum
