Sat, Jan 14, 12 at 23:20
| WOW!! You are certainly going through a LOT of trouble with absolutely no guarantees. This crack should be repaired with injected epoxy. Putting hydraulic cement is only a band aid as it will not penetrate into the crack itself. Hire yourself a waterproofing company to repair this properly, or get the correct kit to fix it yourself. However, if you hire it to be completed, most companies have a lifetime warranty that can be transferred to the next owner. Good luck |
- Posted by lauriedeee (My Page) on Fri, Jan 27, 12 at 2:31
| My husband just did the 'injected epoxy' on our basement wall which had a really bad leak. We ordered online and he says we paid about $150. for the whole kit. It worked. We've had quite a few rainy days here with heavy rains and the leaks stopped. He figured he'd try that before digging out the side of the house to repair it. The epoxy has been in about 2 mos. now and hopefully, it will last. |
Return to the Paint Forum
