What is your go-to color for a small-ish room?
madteaparty33
CHRISTMASGift Giving the Simple-ish Way
If buying holiday gifts drives you to the spiked holiday punch, try these easier but still rewarding traditions
Full StoryDECORATING GUIDESLiving Room Features That Never Go Out of Style
These key pieces will help your living room keep its good looks, no matter what's in fashion
Full StoryDECORATING GUIDESHow to Go Geometric Without Going Overboard
If your home decorating isn’t adding up, consider angles and shapes to help solve the equation
Full StoryMOST POPULARHouzz Tour: Going Off the Grid in 140 Square Feet
WIth $40,000 and a vision of living more simply, a California designer builds her ‘forever’ home — a tiny house on wheels
Full StoryGRAYGoing Greige: Tips for Choosing This All-Around Neutral
Here are some ways to highlight and complement your home with this elegant hybrid of gray and beige
Full StoryMORE ROOMSGo Rogue for Effective Furniture Arrangements
Why stick with a traditional setup that just doesn't cut it? The most advantageous arrangement may be the least obvious
Full StoryWINDOW TREATMENTSHow Low Should Your Drapes Go?
Hover, brush the floor or pool like Scarlett O'Hara's tears — we give you the lowdown on curtain length options
Full StoryGLAM STYLEGlam Home Offices for Go-Getters
Get motivated to do your best in a home office that looks its best
Full StoryHOUZZ TOURSMy Houzz: Going Heavy on the Metal for Industrial-Style Beauty
Steel and iron pieces mix with antiques and heirlooms in an eclectic Netherlands home
Full StoryREMODELING GUIDESClassic Subway Tiles Go Uptown
Get a polished, high-end look from subway tiles old and new
Full StoryMore Discussions
graywings123
Bellevue Painters · Chico Painters · Ladera Ranch Painters · Oldsmar Painters · Tucker Painters · Patchogue Painters · Leicester Painters · Summit Painters · Little Chute Cabinets & Cabinetry · Milford Mill Cabinets & Cabinetry · North Bay Shore Cabinets & Cabinetry · Owings Mills Flooring Contractors · Reading Flooring Contractors · South Lake Tahoe Flooring Contractors · Suitland Flooring Contractors
