Wed, Dec 22, 10 at 19:47
| Hi...I have windows that are about 30 years old. It's almost impossible to open them.. My back is not in good shape and it's actually painful to attempt lifting the
lower window. Would like to use a lubricant to help the situation , but not sure what to use and I don't want to make matters worse. Can anyone help? TIA |
- Posted by krustyoldhouse (My Page) on Wed, Dec 22, 10 at 21:40
| Assuming you are referring to aluminum storm windows, I've used spray WD-40 on our aluminum storms. It helped, but be sure that nothing else is jamming the window, like paint or having the screens and storms in the same track. I also scrubbed the tracks and channels with a brass wire brush. Obv. leaves and other debris can get into the tracks and keep the windows from sliding and seating properly. If these are NOT storms, I can't help you. Good luck. |
| I've gotten good results with Jig-a-Loo, a silicone lubricant one letter away from a racial epithet. |
| snort, snort, coffee all over my computer screen. |
| Paraffin provides an actual lubricant, as opposed to WD40. Most of the contents of the WD40 can is solvent that evaporates leaving nearly nothing behind for actual lubrication. You might need to clean any surfaces the rub together with a Scotch-Brite pad. Aluminum can get pitted and rough enough to cause excessive friction on sliding parts.
Return to the Old House Forum
