Old House Odor
Posted by evecakes7 (My Page) on
Sun, Nov 20, 05 at 14:03
We live in a house that was built in the early 1930's. We're not sure if it is because of the age of the house, but the house will sometimes smell bad. Someone said that it may be from mold in the heating and a/c unit building up -- called "dirty sock syndrome." Not sure if it is this or maybe mold elsewhere. Does anyone have any advice about how to explore this further? Thanks.
RE: Old House Odor
If you have heating and a/c ducts they should be cleaned regularly, even if you don't have an odor, so that's the first thing I would do.
The next thing would be to install a vapor barrier system on the floor of your cellar and any crawl space.
Do you have any carpeting, that would be next. Unless it is newly installed I'd be looking (i.e pulling it up) to make sure the padding and underside are clean and not moist, etc.
In general, lowering the humidity helps.
I have some closets in room that had been left closed up which have absorbed an odor into the plaster. No amount of airing seems to make a difference, so I'm going to paint the interior as a cure.
Sometimes old wallpaper can be smelly.
You didn't say if it was a foul rotten, decaying flesh, or mouse nest/droppings or even old cat pee, those can be persistent and somewhat intermittent smells.
I always find a good, hot scrubbing and forced air drying helps get rid of general empty house smell. I use a mild powdered laundry detergent without optical brighteners and hot water and bushels of towels. I scrub everything, floors, walls woodwrok, ceiling, etc.
HTH
Molly~
RE: Old House Odor
We tore off the back of our 40's home to add on, and found rockwool insulation with unspeakable stuff growing on it. Our GC wanted to blow insulation over it, but I threw a fit and made them take out every bit.
We used to have that 'old house' smell at certain times of the year- high humidity as I recall- we don't have it any more.
I'm going to assume it was the nasty insulation in our case.
RE: Old House Odor
I found a minor ceiling leak which was causing a smell. It wasn't big enough to cause me to notice it for quite some time, but the smell would come and go and drove me nutty. Fixing the leak made the smell worse because we apparently disturbed the mold, but airing it out with fans made it go away eventually.
RE: Old House Odor
People had some great suggestions. I was interested in this thread also because we have an old farmhouse and one room smells different than the rest. Not bad, just wierd I guess. I have removed the old wallpaper, repainted, cleaned the rug and everything I can not figure it out! Must still be the rug maybe.
Anyways if you are having issues with the entire house it does sound that like could be a heating/ac issue. If you don't use the AC or heat for a while does the smell go away?? If it does then I would have your ducts cleaned because that would most likely be the source.
-renee
RE: Old House Odor
If there is a concern about mold, it should be taken seriously because it could be a health hazard. The thing to do is to hire a mold inspection company to undertake a thorough inspection of the house using instruments that measure the concentration of spores. They also measure the heat and humidity levels in various parts of the house, because mold will only grow if the humidity is above a certain level. It is extremely important to hire an inspector who is trained and certified to do this kind of assessment AND WHO DOES NOT DO THE MOLD REMEDIATION, BECAUSE YOU WANT AN IMPARTIAL ASSESSMENT, NOT ONE DRIVEN BY A CONFLICT OF INTEREST. The assessment should take out the guess work in figuring out what the problem is and what to do about it. Inspection costs can vary by more than a hundred $, so shop around.
RE: Old House Odor
Has anyone else actually tried Room Shocker? I am considering trying this product and am interested to see what other people have to say about it. Thanks
RE: Old House Odor
Chlorine dioxide (CLO2) vapour, which Room Shocker claims to release, is a proven biocide used in agriculture and medical facilities.
I'm not a chemist by any means. But I wonder if CL02 can be created and released in such a simple manner as the spammer's supplier suggests. See the link below from a commercial scale supplier.
Local commercial cleaning suppliers should be able to help you out with effective products for specific needs.
Here is a link that might be useful: Chlorine dioxide
RE: Old House Odor
Our new-to-us foreclosure sat empty for 6 months surrounded by woods and a farm. Our Old House Smell was indentified yesteday as a combination of rat, flying squirrel and mouse droppings and urine.
A pest control technician is about to become a very good friend.
Good times.
Return to the Old House Forum
