| I'm hoping some of you have this answer. After removing many layers of painted wallpaper, I've finally hit the original plastered walls.
The original plaster in my kitchen is a very, very smooth substance. Modern paint won't adhere. The 'original' paint shows through, but I've had to skim coat it so I can prime and then paint. I'm sure I've violated some historic plaster commandment....'thou shalt not skim coat original plaster walls...'. But, I don't know what else to do. It's too late now as it's done, but this is only one room and I can mend my ways for the next room. Picture is below to help clarify. The chunks are wallpaper remains on the blue paint
Thanks for any help!
| There may be calcamine on the wall. Plaster is usually very easy to paint, even with latex. Even if you try to skim coat a bonding agent may not stick either (they are just thin glue). |
| Thanks for the reply, Brickeyee!! What is calcamine? I've never heard of that. What was the original purpose of it used for? How would you 'fix' it to ready it to paint? You may be correct, because in some areas, even the plaster didn't stick. I had to sand it, then replaster and then finally prime. Thanks again!! |
| I've not used it, but I have had surfaces finished in Calcimine. I only had adherence problems in one room. But, it can be a bugger. I found this when I googled. Hope it works and waiting if Brickeye has suggestions. |
Here is a link that might be useful: Calcimine coater
- Posted by christophern (My Page) on Mon, Nov 17, 08 at 5:55
| You will need to sand it all , clean,apply Gardz,skim,sand,clean apply primer,( can be Gardz again)paint |
Here is a link that might be useful: calcimine
| "You will need to sand it all..." Not a good idea unless there is no other option. While most lead is lead acetate used as a drier and gloss improver, it may be present in very old houses as lead oxide pigment. |
| Thanks for the information. I really appreciate it! :) |
Return to the Old House Forum
