| Soooo, all over my house, the P.O.s added layers. I am slowly peeling them back to reveal an 1887 victorian.
My latest venture is the ceiling in a small 2nd floor room. I figure, start with a small room, see how it goes, and work my way up to a big project, like the dining room where the new ceiling layers are obscuring part of the crown molding. I have figured out that they covered all the ceilings with 1/2 drywall, 3/8" brown coat (but I really think they used cement), and a skim coat of mopped plaster with ugly little flecky balls of plaster stuck in it. I call it low-budget popcorn. It's GREAT! So, I'm trying to remove the plaster and sheetrock without damaging the original plaster ceiling above it. If I actually manage to do this, I'll patch as needed, do a calcimine protocol (scrubbing with tsp and water, rinsing well) and then use BM calcimine recoater. So far I've gotten about a 12" square off. The ceiling looks surprisingly good. I can't understand why they covered it! I figured it would have to look pretty bad for them to go to all that trouble. But the removal is slow going. I've been using a dremel multi tool to cut a 6" grid and then I pry off the squares. The blade is dulling fast on the "cement" plaster. Is there a better way????? Part of me wonders, am I destroying a really awesome soundproofing job? Maybe I should just knock off the flecky balls, skim the mopped swirls (I tried sanding them and they won't budge), and call it a day. But in the dining room, that won't work. This room is only 6 x 8 so it's good for practice. And, the inch I gain, while not much, will greatly increase the proportional size of the cramped strip of wall between the window trim and the ceiling. Oh, I'd prefer not to rip out the whole ceiling and sheetrock; I don't much like the acoustics of sheetrock. |
| Beware that the plaster may very well be cracked and falling down in the portions you haven't gotten to yet. I know when I've drywalled over plaster ceilings that was exactly why I did it. |
- Posted by lazygardens (My Page) on Wed, Oct 31, 12 at 22:08
| ^^^^^ What he said! The usual repair for a sagging plaster ceiling is to put thin drywall over it as a giant bandaid, then finish the drywall. Don't be surprised to find missing or detached chunks. |
- Posted by liriodendron (My Page) on Thu, Nov 1, 12 at 0:02
| And the drywall may have been stuck to the plaster with glue or contractor's epoxy......... Can you contact the previous owner to find out? I think I would go to some trouble to do so before starting on something that might be more work to rectify if you find the plaster underneath in terrible shape and falling down on your head. The only reasons I can think for doing that to intact plaster would be for soundproofing or weatherization. And those would be an extreme stretch to imagine why you go to all that trouble. I think if the plaster is covered it wasn't just because they didn't want to deal with the calcimine-painted ceiling. Sorry! Still even if the plaster is totaled, it's not the end of the world, just perhaps very expensive to fix. That somewhat depends on how common plaster is in your area. In places where there it is still even somewhat common, you'll have more luck - and probably better prices - than in those areas where it is strictly a restoration-quality material. You could learn to do it yourself. Whole ceilings scare me; I'm still working myself up through small -to- medium sized patches on walls and ceilings. I do have a whole ceiling to do, but it's not on my schedule, yet. So for awhile longer it can stay a combination of plywood and sheetrock. L. |
- Posted by christophern (My Page) on Thu, Nov 1, 12 at 5:24
| Although I somewhat agree with what has been said, you just never know what people were thinking. I would proceed with what you are doing, taking it slow and careful and see what it up there. I have been in this situation and found pristine plaster under all that crap. Who knows? |
- Posted by slateberry51 (My Page) on Thu, Nov 1, 12 at 8:20
Here is a link that might be useful: trunk room: scroll down to the before and after pics at the end
| Are you using the multi-tool to do vertical cuts? If you could reliably establish the depth you need to cut, you could use a Sawzall with the depth marked on the blade. I can't imagine how much work this must be. |
- Posted by slateberry51 (My Page) on Thu, Nov 1, 12 at 12:37
- Posted by liriodendron (My Page) on Thu, Nov 1, 12 at 12:53
| That radiator is fantastic! I'm not sure I'd call it Chippendale, but it is to die for, nonetheless. Maybe you'd feel more comfortable if you set up some scaffolding with a wide (even nearly whole room) platform you could move around on more easily instead of being on a ladder. I know it sounds like a lot of extra work, but whenever I've gone to the trouble of doing that (setting up a raised work platform) I am so grateful for it. I always start the hard way - and sometimes finish that way, too - but the smart way is to set up the work area right from the outset. I am heartened by your description of the PO's approach to remodeling. It makes it seem more likely that the sheetrock may not conceal a plasta' disasta'. Or at least not in every room. I wish you very good luck. L. |
- Posted by christophern (My Page) on Fri, Nov 2, 12 at 4:56
| Like I said, people are strange.Have fun and spend a little $ on proper tools. You will never regret it in the long run. |
- Posted by slateberry51 (My Page) on Fri, Nov 2, 12 at 10:05
| Christophern, Now you've got me curious: by proper tools, do you mean scaffolding, or a rotozip, or the right kind of saw blade (which I think I got--it's a diamond masonry blade, except the box store didn't have it in 5"), or would you recommend something even better)? The only downside of using the little 3" saw blade in my circular saw, which normally takes about a 5", is that the rpm's are not adjustable, so I'm not really spinning the 3" blade at the optimal speed. But, it's still cutting like a champ. A rotozip would be better. Is that what you used when you did this? |
- Posted by christophern (My Page) on Sat, Nov 3, 12 at 17:32
| I was not being specific, if the circular saw is working, go with it.Just in general, a good tool will last a long time and do a better job.In my profession, it is like using a $20 paint brush as opposed to a $2 brush for Lowes, there is a big difference in performance. |
- Posted by antiquesilver (My Page) on Sun, Nov 4, 12 at 1:48
| WOW - that radiator is fabulous! I've never seen one like it. |
- Posted by slateberry51 (My Page) on Sun, Nov 4, 12 at 6:47
| Thanks! I love it too. I shouldn't have called it Chippendale. I think Aesthetic movement Japonaiserie might fit better. I really, really love this stuff. Of course, I also like Persian tile and rug field patterns. |
Here is a link that might be useful: Example of Japonaiserie pattern
| Quality stilts are likely to p[y off more for interior work than scaffolding. |
- Posted by columbusguy1 (My Page) on Mon, Nov 5, 12 at 18:41
| That is a great radiator, slateberry! You are lucky the previous owners didn't rip it out or sell it! I'd love to see your porch opened up again, if not restored to it's full length...the nice thing is, you can cover up the concrete with wood! :) As a side note, I really hate it when sites which try to represent themselves as professional, can't even spell their own topic! :) |
- Posted by slateberry51 (My Page) on Tue, Nov 6, 12 at 8:51
| My you are persistent! But I wonder if a a skim coat or two over the drywall might have gotten you the same results with a lot less work. That's an amazing rad! (Though not likely very efficient due to the limited surface area vs. traditional types. ) |
- Posted by columbusguy1 (My Page) on Tue, Nov 6, 12 at 20:34
| Sure we can, slateberry--it was the alleged 'Japonaiserie' site I was poking...they have it spelled that way, so you aren't to blame. :) I have to do some work on the ceiling of my pantry--stupid remnants of the hurricane came from just the right direction to cause my pantry to leak--nothing major, but it certainly caused the old painted paper to peel off! Can I just say I hate repair people? Last week I called four or five places to get estimates to fix the roof--it's only about 175 sq.ft.--and only one company got back to me. They gave me an estimate today to remove the asphalt shingles, put down ice dam self-sealing stuff and put up new shingles at what I thought was a good price, so I gave them the job. Should take only a few hours, but they can't get me in for a week or so. When I told their rep about not getting call backs, he said it was because few people wanted a small job, which would take almost a day with cleanup, when they could do a large job in the same time frame. Bastards--I'm just glad there are some companies that will still do small jobs...but you have to dig for them! |
- Posted by slateberry51 (My Page) on Sat, Nov 10, 12 at 18:18
- Posted by slateberry51 (My Page) on Sat, Nov 10, 12 at 18:21
| I meant to say I tried different putty knives for prying, and a 5" wide putty knife with the right flex (fairly stiff but more flex than a chisel blade) worked the best. |
- Posted by slateberry51 (My Page) on Mon, Dec 24, 12 at 9:02
Return to the Old House Forum
