fixing old tiles that are coming loose
Posted by melissastar (My Page) on
Fri, Oct 18, 13 at 10:14
The century-old tiles in my fireplace surround (an original, now unused gas fireplace) are coming loose in places. Some are still adhered well, but in a few patches, groups of 3 or 4 tiles are pulled away from the wall and only the grout and gravity is holding them vertical.
I haven't any idea how to go about repairing this, but am hoping it won't involve removing all the tiles and putting them back.
Suggestions? Resources? All help and advice welcome!
RE: fixing old tiles that are coming loose
If you can remove the loose tiles without destroying them, they can be reset and regrouted. Use a grout removal tool to detach the loose tiles; then clean, reset and regrout.
Thanks worthy. Reset using what exactly? Do I need to dig out the old mortar behind them? And if not, won't it make the tiles stick out further?
Yes, carefully remove the old cement and use a bit of mastic to set them again, being careful to keep the same spacing for the grout lines using a bit of cardboard or plastic spacers.
Return to the Old House Forum
