casement windows: convert pushout stay operation to winder/crank
Posted by kaw1 (My Page) on
Sat, Oct 4, 08 at 7:42
is it possible to convert my 1920's timber casement windows from their current pushout stay operation to a winder mechanism? The stay is attached to the middle of the vertical edge of the window and i think a winder would need to go on the base of the window.
I really want to be able to lock the windows open and to install a fixed timber flyscreen to the windows and can't with the stay operation as a) they dont lock and b) the stay juts inside the room when the window is open.
installing a winder/crank is the only solution i can think of but i am not sure if this is feasible. any suggestions on how to do this or alternatives would be great.
RE: casement windows: convert pushout stay operation to winder/cr
I have a 1920 Bungalow with two casement windows.....They were "site built" using an off-the-shelf steel crank-operator.....
Here's a very similar BRASS operator.....the removable square-shaft handle passes thru a hole in your Interior-fixed-screen-wooden-frame to reach the operator......
Here is a link that might be useful: SWISSCO
thanks, this looks like it could work. are you happy with yours?
Oh.......I re-found my LINK to the Exact copy of the original 1920's operator....(alot more $$ than the Stamped-brass one above)
https://www.blainewindow.com//catalog/iteminfo.cfm?itemid=4662&compid= 1
Very substantial.....easy to operate (and install)
Here is a link that might be useful: Blaine Casement operator
Here are a couple photos....Be kind.....remember these are 80+ years old.....
Return to the Old House Forum
