| Hello,
I live in Atlanta, Ga and purchased a 1-story 1200 sf, 1930s bungalow on a +/- 2' brick crawl space. It is in need of updating and repair, which I am in the middle of completeing now. I have completely gutted a bathroom and kitchen and rebuilt from the piers up. I have subfloor down but still have exposed stud walls on the interior. When I did the interior demo work I was amazed to see that the 1x12 exterior siding was nailed directly to the studs on the wihtout any exterior sheathing or vapor barrier. My question is before I install drywall what is the best way to insulate these walls and install vapor barrier if necessary without removing all the siding?
| I'm no expert, but I think that's the way most of the older houses up my way were built. Studs and 1x12 boards as sheathing with 1/4 gaps (or more) between. Your siding goes on top of that. I think that I have tarpaper under the clapboard siding on my place. Are you saying that you have 12" wide siding with no tarpaper? So, don't people put the vapor barrier on the inside of the wall to keep the insulation dry? The outside should be protected from water, but still be able to breathe, right? jf
| Clint, what you suggest sounds good to me. An alternative may be to but up blue rigid foam insulation sheets before the drywall. Studs radiate cold and if you put rigid foam on top of your studs, it's effectiveness is quite a bit higher than bats between wood studs. Cold walls are caused (mostly) by studs radiating the cold. Your order of vapour barrier is correct. Vapour barrier has to be on the warm-in-winter or cold-in-summer side of the insulation. If your siding is leaking water, then that needs to be fixed and is a different topic than a vapour barrier. You can think of a vapour barrier as "when heating or cooling, a vapour barrier is where the condensation will form". |
- Posted by glassquilt (My Page) on Thu, Oct 6, 05 at 14:27
| After living in the house he built in 1950, my dad decided to insulate in the mid-80's. The house was concret block, tar paper & stucco. The inside was plastered. Rather than face the mess of removing the plaster he put the insulation over the plaster and dry walled. He put the furring strips at right angles to the original studs because of the transfer of cold. I don't remember his reasoning but he put a vapor barrier against the plaster & a second one next to the dry wall. The house was wonderful when he finished. |
| Dear JF, There isn't any sheathing or tar paper. The 1x12 on the outside is the siding. Does that change any of your thoughts? Thanks for the help. Clint |
- Posted by fourthsibling (My Page) on Mon, Sep 1, 08 at 17:09
| I just read this thread and want to add my question to the original. I am in East Texas. I plan on converting an old woodworking room into a studio. It is 30 years old and was done the same way; i.e., rough plywood sheathing directly over the studs. It is paneled in the cheapest rough particleboard the owner could find (looks like a pile or large wood ships and shreds were simply saturated with resin, then pressed into shape), but the paneling is in good shape and I don't really need to remove it. We though about just adding a vapor barrier, then covering the entire thing with a new layer of paneling or drywall. The questions are: If we add a vapor barrier, where does it go - on the outside of the building with a new layer of siding over that or on the inside with a new layer of paneling over that? And where would the insulation go? Dian |
- Posted by mightyanvil (My Page) on Mon, Sep 1, 08 at 19:29
| Start a new thread so readers don't have to read through an old dead one to find your question. |
- Posted by fourthsibling (My Page) on Mon, Sep 1, 08 at 21:53
| Thank you, Mightyanvil. I will do that. Dian |
Return to the Old House Forum
