Sandblasting my old house?
Posted by floete_ri (My Page) on
Fri, Sep 18, 09 at 17:06
I've had 3 painting contractors over to look at the exterior of my 1930 bungalow recently and *none* of them would take the job or even offer a bid. Simply put, paint won't stick to the exterior of the house. We had it sanded and painted four years ago and it was bubbling all over the place w/ in a year. We've lived with it since then.
Some of the guys just shake their head, others talk about moisture and lack of ventilation. But one thing they can all agree on is, the house just has too many damn layers of paint on it. And nobody wants the job of getting the paint off ...
Until today. Today a nice guy stopped by and said the only economical way to do it is sandblasting. Wow, cool, I thought. But then I search on the 'net and found that nobody likes or recommends sandblasting (or glass blasting, as this company calls it); it ruins the wood one way or another.
My question is: is that absolutely true? Does sandblasting always result in disaster?
Thoughts anyone?
thanks!
RE: Sandblasting my old house?
We decided against sand blasting really damages brick,we had ours washed ,it was bio degradable.we did it in 93 looks as good as the day they did it.
In my case, however, we're talking about clapboard instead of brick. that said, damage would probably be worse on wood. but i'm not sure we have another choice at a price we can afford.
I'm going to ask the painter for some references to sandblasted houses and go see what they look like.
Meanwhile, if anyone else has any input or suggestions ... feel free!
Check other current threads on this forum about paint removal that make reference to infrared heat for paint removal. Not that I've ever used it, but it seems that people do use it to strip the entire exterior of their houses.
Blasting, whether with sand or glass beads or even walnut shells seems to me would make an infernal mess, and if some of your layers are lead paint... well, enough said. Again, read the other threads, one linked below.
KarinL
Here is a link that might be useful: Stripper info
Check out this YouTube video on Dry Ice blasting. Another option to consider...
http://www.youtube.com/watch?v=A-Gy4I8jSHE
Diane
Here is a link that might be useful: Dry Ice Blasting
Check this piece at This Old House on a water-based chemical stripper that requires few safety precautions.
RUN Forest, RUN!
We used chemical wash,it was biodegradable didnt hurt shrubs,flowers never had 1 problem from it.They started top of the house came down it got rid of all paint etc on brick,the windows had white paint chaulking running down brick,it got rid that,It looked great when done a real face lift.like I said we did it in 93 it still looks great.
We have a ranch and there was so much paint on it hubby took a pressure washer to it but you have to watch which tip you use or you can carve out the wood. We let it dry for a week and then we sanded (along with friends) and primed and painted. I would never do it agin, only because it's alot of hard work. I wish we would have slapped up some vinyl siding instead but otherwise the paint job looks great!!
Return to the Old House Forum
