Sealing box gutters
Posted by Zelie4111 (My Page) on
Fri, Sep 13, 13 at 16:29
My box gutters gave been tarred several times over the years which tells me it is probably not a great idea to use rust oleum paint as should have been done in the first place. I am looking into roof sealers instead of tar this time because the tar never seems to work. Any ideas?
RE: Sealing box gutters
First determine if the previous coating was coal tar or modified asphalt because they are not compatible with each other and with many other waterproofing coatings. This may not be a good DIY project.
My box gutters were leaking at a couple corners when I bought the house in '87, so a few years later when the roof was redone, the roofer used a rubber membrane to line them. I haven't had leaks from them since then. It is a black rubber, which is all I can say about it--I don't think there was ice dam material back in '92, so I'm pretty sure it's nothing exotic--just make sure its well adhered.
Return to the Old House Forum
